Top radiator hose
Top radiator hose
I need a top radiator hose from the F-body water pump to upper driver's side 1.5" port. Anybody have a hose reference?
Re: Top radiator hose
Elbows with aluminum radiator pipe is what I am switching to, my upper hose is too thick, not a 928, but same concept.
If you can't find a part number for the hose, you can go to the parts store with a bent piece of clothes hanger & inlet / outlet diameters and ask them to let you behind the counter to sort thru the different hoses. I ended up having to splice a couple together with tee's I bought from jags that run. The tee's had fittings for the steam pipe and another had a fitting for the reservoir. I'm using a universal rad though.
I found a solution. Still waiting on a 32mm to 1/8-27 NPT hose adapter so I can plumb in the front LS steam vent.
Dayco part # 71132 will fit and Dayco 71085 will fit with a 32mm (1.25") water port adapter spliced in for the LS steam vent line that comes from the front driver's side head.....
1/8 27npt is the thread size of most of the jointers that take a water temp sensor, Im using a 32mm one for an adjustable fan switch
toysche928- Posts : 3
OOPS! replied to old post,Just read your thread on 928 swaps,noticed you allready have one up and running.
Today at 8:08 am by gwistrup
Yesterday at 11:12 am by Nath1142
Mon Apr 22, 2024 8:22 pm by lowform
Mon Apr 22, 2024 8:12 pm by lowform
Tue Apr 09, 2024 2:54 am by lowform
