Variable ratio brake pedal
I have had an idea for a couple years now about our brake dilemma. I have sketched out a design for a variable ratio brake pedal which would help decrease the stroke during low braking application but would increase the mechanical advantage as the required brake force increases. Due to the design the system would be a little less linear than a straight non-power assist.
Speedy:)
Speedy:)
speedracing944- Posts : 43
Re: Variable ratio brake pedal
speedracing944 wrote:I have had an idea for a couple years now about our brake dilemma. I have sketched out a design for a variable ratio brake pedal which would help decrease the stroke during low braking application but would increase the mechanical advantage as the required brake force increases. Due to the design the system would be a little less linear than a straight non-power assist.
Speedy:)
Pictures, please.....
porschyn- Posts : 9
I would love to build a prototype and test it's effectiveness first before releasing pics.
Speedy:)
Speedy:)
