Just the alternator and H2O Pump please
I will only need an alternator and water pump on my track car. Does anyone have suggestions on the proper setup (brackets etc.) for an LSx? I will be using a 5.3 block. Thanks in advance. Gene
968gene- Posts : 259
Re: Just the alternator and H2O Pump please
I used these guys for my LT1 brackets. alittle pricy but they look nice and work. They seem to have most options covered somewhere.
Phatjimmy- Posts : 17
I want to run that exact set-up. I was hoping that someone could groove the waterpump pulley??? And just tension the alt like gen1's did. That would be awesome.
On my LT1, I ran just an alternator right off the crank and tensioned it just by pulling on the alt a bit and tightening it down. Worked great and no need for a tensioner or idler. Unfortunately, the only way I can see to do this is with the LS engines is to have an electric water pump.
Once I get my engine settled in, I will start this little project.
I second the electric WP.....then its just an Alt, that should be easy.
» alternator and ps pump fitment
» What to do with blue wire on 2-pin 944 alternator/starter plug when ECU controls alternator?
» Seeking Basic Charging System Wiring Guidance
