» JP's LS1 Conversion
Yesterday at 8:32 pm by jpkinerk
Yesterday at 8:13 pm by gdopnt
Yesterday at 9:56 am by superman22x
» LS3 Exhaust
Sat Jan 20, 2018 11:12 pm by sharkey
» Steering shaft short
» ecotec swap
» 86` 944 turbo project
» alignment specs
Fri Jan 19, 2018 4:22 pm by Hotrodz of Dallas
» 1984 Gen IV 5.3 Swap
Fri Jan 19, 2018 2:03 pm by superman22x
January 2018
Just the alternator and H2O Pump please
Post  968gene on Wed Aug 26, 2009 8:21 pm
I will only need an alternator and water pump on my track car. Does anyone have suggestions on the proper setup (brackets etc.) for an LSx? I will be using a 5.3 block. Thanks in advance. Gene
968gene
Re: Just the alternator and H2O Pump please
Post  Phatjimmy on Thu Aug 27, 2009 8:42 am
I used these guys for my LT1 brackets. alittle pricy but they look nice and work. They seem to have most options covered somewhere.
Phatjimmy
Post  944-LT1 on Thu Aug 27, 2009 4:34 pm
I want to run that exact set-up. I was hoping that someone could groove the waterpump pulley??? And just tension the alt like gen1's did. That would be awesome.
On my LT1, I ran just an alternator right off the crank and tensioned it just by pulling on the alt a bit and tightening it down. Worked great and no need for a tensioner or idler. Unfortunately, the only way I can see to do this is with the LS engines is to have an electric water pump. Crying or Very sad
Once I get my engine settled in, I will start this little project.
Post  948 on Thu Aug 27, 2009 6:06 pm
I second the electric WP.....then its just an Alt, that should be easy.
