Hydroboost mounting
Hydroboost mounting
Hello Folks
I am doing a little back paddling and trying to mount the hydroboost unit and had a couple of questions to those that are using hydroboost.
Do I mount the hydroboost at the stock 944 brake pushrod location ?
Are there any clearance issues ? coils, valve cover, shock tower.
What thickness firewall reinforcement plate are you using ?
One more, Does anyone have fitting numbers if I go with AN adapters ?
Thanks in advance for any help.
I did a search of the forum but could not find any definitive specifics on the mounting.
speedsterman- Posts : 22
Hydroboost
Try again, use the advance search function, the answers you seek are all there.
This topic has been covered a few times.
Re: Hydroboost mounting
Here are some threads i had book marked, i made a little 'fact' sheet for the shop doing my conversion to make there life easier..
https://944hybrids.forumotion.com/t259-hydro-boost-install - Indexing info
https://944hybrids.forumotion.com/t1689-hydroboost-mounting-plate
https://944hybrids.forumotion.com/t1956-hydroboost-fitting-help - Fitting info
https://944hybrids.forumotion.com/t1580-my-latest-project-comes-to-an-end-nearly - General install pictures
http://classicbroncos.com/hydroboost_cobra.shtml
Here are the fittings,
-high pressure hydroboost fitting, from the pump: RUS-648080 18mm x 1.5 O-ring Seal to -6 AN $13.69
-high pressure hydroboost fitting, to the rack: RUS-670530 16mm x 1.5 to -6 AN $4.95
Techno Duck- Posts : 447
I'm going with Earl's fittings as they're steel. Russell only offers one of the fittings in steel.
Those part numbers are 961956 (18mm x 1.5) and 961955 (16mm x 1.5).
I'm trying to dig up thread sizes for the HB return line and brake lines at the moment.
Guest- Guest
Thanks for the information. I am trying to locate adapters for the Porsche rack. The banjo adapters that I am finding are sometimes listed as "fuel rail" fittings. The size matches and the machining looks sturdy enough. Any concerns? I think they are on Ebay as Honda fuel rail adapter, 12mm banjo to 6 AN.
I did a bit more research and pricing for the hydroboost fittings and I ended up going with Hydratech part HBS9102. It comes with two banjo fittings for the in/out pressure sides and an AN fitting for the return. All -6 AN. I was only going to purchase the return fitting but I liked the low profile of the banjos.
As to the rack fittings I've not been able to find steel -6 AN banjo fittings. The bolts are easy - they're 12mm x 1.5 - but all the banjo fittings are -4 AN as they're all intended for use on brake calipers.
The alternative, which I plan to do at the moment, is use Pegasus part 3276-003. I'm not 100% certain this part is correct as I found it here on the board. I'm going to order it and find out.
Guest- Guest
You can use metric ORB to JIC fittings, Pretty sure it was Hydratech.
Dont need to reinforce the firewall IMO
Search my posts, i'm sure I posted my mods and numbers on threads.
Wild Bill- Posts : 121
