power steering pump choices
+4
Vorsche944
speedsterman
8 posters
Hey folks,
I wanted to hear what everyone is using for power steering pump options. I was thinking of using a Turn One pump. Anybody having good luck with this option. Was thinking of fabricating a conversion jack-shaft for the 944 pump, but the Turn One would be a lot simpler .
speedsterman- Posts : 22
Re: power steering pump choices
I contacted turn one about modifying my GTO power steering pump to match the Porsche power steering rack and hydroboost brakes. They said they could do it for $75.
I use stock GM pumps with and without hyro boost a and have no problems. I've also use the Turn One pumps with good luck as well.
What is hydro boost? Does it boost the power steering pressure?
Simple picture to better understand the PS pump, Hydroboost, and PS Box set up.
I run the Turn one with Ford HYdroboost and PS. Really like the Hydroboost.
Is there a certain Hydro Booster unit that fits well? What year and model Ford unit are you using? Thanks for everyones help.
Mustang from 2000 to 2004, Other people have had good luck with the BMW setups as well.
Anybody use any GM units. I see some people using some off of diesel GM trucks. They are putting them on old 4X4's, (Broncos, Jeeps)
GM Booster
Here's a pic of a 70s era GM booster, looks pretty compact. I don't know what else is required for this unit.
I've got the Ford Mustang unit with a Turn 1 pump. It works well, but if I had to do it again I'd use the BMW system as it lets you retain the Porsche master cylinder and your brake bias doesn't get screwed up.
Anyone tried mounting the Porsche master to the Ford Hydroboost?
xschop wrote:Anyone tried mounting the Porsche master to the Ford Hydroboost?
No, but I'm going to. I'll post up how it goes when I get to it.
You wouldn't happen to have any more of your HB mounting kits, would you, Xschop?
Guest- Guest
Rob , we tride the Porsche master cylinder but it was to much trouble. You will need a mounting plate between the two and a custom push rod. The mustang master has metric threads and works well for most applications.
Not to hijack the thread but...
Admin, have you (TPC), or anyone else for that matter, considered offering power steering lines and hydroboost lines for use with the mustang hydroboost and turn one powersteering pump?
TPC has done enough of these now that these should reproducable. I would rather buy these premade than have to trial and error...
What do you think?
What do you think?
