And it begins....Tim's 86 951 LS1 swap
+2
Tim
6 posters
So, not a whole lot going on right now. Removed engine and sourced an LS1 (98 Camaro). Now it's parts acquisition time! My goal is to just make a fun street car. I already have a track car, so no need for another.
I'm sure I'll be posting a ton of questions here. I've already been bugging Josh (DocWyte) about his swap since he's just down the road a bit.
If this goes well, I'll probably swap one into my E36 BMW too.
Anyway, here are a few pics to show at least a little progress!
Re: And it begins....Tim's 86 951 LS1 swap
Good progress! Let me know if you have any other questions...
Looks like it's off to a clean start! Should be a blast when you're finished!
just FYI the 98 LS1 blocks had a problem with rod bolt failures leading to spun/thrown rods. Mine lasted all of 20 minutes on the track before throwing 2 rods and seizing the motor. Before you go any further I would highly recommend 1)new Katech or ARP rod bolts 2)high volume melling oil pump 3)drilling your lifter buckets 4)new LS2 timing chain. These 4 mods greatly enhance the reliability of the 98 motor
eclou- Posts : 102
Thanks for the heads-up!
Already ordered 1 and 4. Maybe 2 and 3 to come.
This car won't see any track action, though. Just the occasional autocross.
Alrighty, lots of parts purchasing progress made!
-LS6 manifold with ported TB (Thanks, Josh!)
-Test pipes and cat pipes (Thanks again, Josh)
-Oil pan (TPC...Thanks, Eric!)
-Motor mounts (TPC...Thanks, Eric!)
-VSS kit (TPC...Thanks, Eric!)
-Crossmember spacers (TPC...Thanks, Eric!)
-Pilot bearing and adapter (TPC...Thanks, Eric!)
-Spec Stage 2 clutch and flywheel (OEM Part Haus)
-QuickTime Inc RM-6033 bellhousing (OEM Part Haus)
I need to figure out my brake booster setup, but other than that, I think I'll be ready to start playing.
Am I forgetting anything?
Fuel filter stuff. Brake stuff. Radiator?
Happy to help out!
Happy to help out!
Using a new stock radiator. I believe I'm going with the E32 booster also.
Now I just need to figure out the fuel filter issue.
I've got a spare one in my garage for you...
How about your oil system? Eric's pan has -10AN in/out fittings and you'll need to figure out a remote oil filter and a cooler.
Not on his pan! He's getting the new version that has a screw on filter
docwyte wrote:I've got a spare one in my garage for you...
Spare what? Fuel filter, right?
Yep, spare fuel filter
I forgot about that. I believe that comes free with the purchase of LS6 intake, TB and exhaust.....right?
