Cracked Bellhousings? Bueller.... Bueller???
+3
skywalker01
7 posters
Trying to get feedback on anyone experiencing problems with their LSX bellhousings cracking/splitting. I am dropping my engine over the winter for upgrades and re-running of fuel lines and noticed that my bellhousing is cracked. This is the second time that this has happened to me - I am wondering if this something specific to the stresses of autocrossing or something else. At any rate, I think a QT bellhousing is in my future.
skywalker01- Posts : 477
Re: Cracked Bellhousings? Bueller.... Bueller???
Was it a used BH? I'm told corvettes involved in a wreck often have small stress fractures to the bell housing afterward.
944convert- Posts : 253
You need to support the transmission from twisting during acceleration and deceleration. Remember that the motor is only on two mount points in the from and late model cars only have one tiny point holding the trans, something will eventually give!
No problems with my QuickTime bell housing after 3 seasons of road racing...
Go with the QT bell housing , they are heavy but you won't break it.
The extra 15-20 lbs is more than made up for with power. Plus it has an integral scatter shield.
No this was a brand new GM unit that I ordered last year after discovering that my first bellhousing had fallen to pieces. Eric - you'd think that the motor mounts would really prevent the rotation tendencies. I have an '83 944, so I have billet mounts on both sides of the gearbox. Hard to believe that I still have movement with solid mounts all over the place.
If you've hard-mounted the trans and the engine then the unibody flex will continually pop the bellhousing as it's the weakest link.
Okay - I can accept that (Body Flex). So the QT Bellhousing will be on my Santa list *sigh*
If you go to the qt bellhousing, then the next weakest link will be your point of failure. It could be something that would suck even worse to crack. My suggestion would be to back off from those solid trans mounts, something stiff for performance but that would still allow a little movement if you did get some flex in the body.
Next thing that to fail would probably be a gear in the transmission since the CV Joints have been beefed up. May just need to stiffen the body some.
Makes sense...are all your mounts "solid"?Rich L. wrote:that would still allow a little movement if you did get some flex in the body.
Yeah, all of the mounts are solid. Thought they would be a 'good thing' but I guess with 305 sized Toyo R888s, something's gotta give.
I've seen a couple cracked 951 Bells before due to hard mounts as well. IMO a poly trans mount/mounts at the rear and rubber/soft poly engine mounts at front are ideal..JAT
My transmission mounts have a poly bushing up at the chassis bolt hole - it's appears that they don't allow for much, but I had to dump the Energy Suspension motor mounts because they were looking like the polyurethane was coming apart from the metal mount.xschop wrote:I've seen a couple cracked 951 Bells before due to hard mounts as well. IMO a poly trans mount/mounts at the rear and rubber/soft poly engine mounts at front are ideal..JAT
That is classic body flex killing the engine mounts.
So tower brace? Cage?? All of the above???
Cheapest solution is to use engine rubber mounts and keep your billet/poly trans mounts:D
Def. a strut brace if you don't have one. I'm working on my custom 928 brace this weekend:DÂ
Get a lower rear A-arm brace while you're at it.
if theres body flexing wouldnt a strut tower brace and some sub frame connectors prevent it?
shokwave30- Posts : 68
