Tue Jul 09, 2013 4:56 am by Admin
Warning light on (!) during drive
This is the second time this has happened now, once on a very hot drive to the mountains (100 miles) and then again yesterday (110 miles). I have driven the swap about 12k miles now and as my DD since May. My daily trip is only 13 miles and have driven about 60 mile trips but it seems like the 100+ is the trigger for the center dash (!) light. Any ideas? Last time it happened tried to pull codes which it didn't have any but the light went off. All temps, gauges and electrical things working.
Thanks!
Thanks!
rdanford- Posts : 96
Re: Warning light on (!) during drive
You can buy a code reader for cheap money at any auto parts store.
acorad- Posts : 697
Got codes pulled...air injection malfunction and clutch switch malfunction. Any thoughts? Cleared codes and didn't come back on.
Clutch switch is one of those things that should not matter as our cars don't use this, The Air injection is the emission air pump, either the relay is not working or it is going off/on at the wrong time in the 100 plus mile journey .
Not too worried now as I have them cleared. Where is the air pump relay?
Maybe Admin is more familiar with your swap, but the "!" normally wouldn't be tied to anything related to the engine swap (that is, unless you wired your CEL into it).
It usually just means one of a few things:
-Brake pads worn
-out of brake fluid (you should have just cut those wires)
-oil pressure connector
-e-brake not seated fully
...that kind of stuff.
-Brake pads worn
Today at 8:08 pm by gwistrup
Yesterday at 11:12 pm by Nath1142
Tue Apr 23, 2024 8:22 am by lowform
Tue Apr 23, 2024 8:12 am by lowform
Tue Apr 16, 2024 8:28 am by JW1970
Tue Apr 16, 2024 7:59 am by JW1970
Mon Apr 15, 2024 10:51 pm by Raymond-P
Sat Apr 13, 2024 4:07 am by Rob44
Thu Apr 11, 2024 11:09 am by LS982
Tue Apr 09, 2024 2:54 pm by lowform
