big brakes and ABS
big brakes and ABS
Does anyone still run there ABS. Does anyone have a big brake up grade and running ABS. If so what is needed. Thanks.
kevin924kevin- Posts : 927
Re: big brakes and ABS
This should fit the bill....
http://forums.rennlist.com/rennforums/944-turbo-and-turbo-s-forum/676140-951-v8-with-boxter-986-911-996-abs-done.html
I'm running the factory ABS with Turbo S rear brakes and Big Reds up front. No problems.
brakes
Thank you, is yours the 951 system. was there any changes needed. My car is a 78 so no ABS, but i have changed everything to the S2, so the car has the hubs and sensors, so what would be left, pump, brain, oh what master are u using and is it boosted. Much appreciate the info.
Yes, my car is a 944 Turbo S, so it had all that stuff stock. Ford hydroboosted master cylinder and I use an adjustable Tilton brake proportioning valve for the rear brake bias.
If you're adding ABS, you should look into getting the Boxster ABS brain, look on rennlist for TonyG's post about it.
brakes
Thank you all, printed out all the info about tony's brakes.
brakes
I think this can be a relatively cheap process, judging by the costs on ebay for the pumps etc, not a bad addition to our cars that dont have ABS.
