Late Struts
Late Struts
Looking for a set of late struts to do some experimenting on. Fried dampers no problem.
years
87-up should all have the Late spindle pinch bolt spreadwidth of 63mm C2C.
Someone screwed up and said I couldn't put Late Spindles on Early Struts. (the Early struts use easily replaceable strut inserts of which I have already modded for coilovers)
For that matter if someone has an Early set they want to get rid of also let me know.
Re: Late Struts
I have my 84' na that I am going to part out. I will ask a local about the 87-up and see if he has some.
EDIT
I am only interested in Early Struts if you have a spare set. No Need to bother with cutting up a late set to do the Conversion. Thanks, Chop
