HPT951's track car build
+7
RobotMachines
hpt951
11 posters
First off I have to thank all the members on this board for the excellent info on here! Then, Eric at TPC for answering all the minor questions (about 100 emails!) I had along the way
My car started out as an E class PCA racer, ran it for 2 seasons, then switched to 18 x 10's and 285's all around. The engine let go the last event of 2011! Perfect time for an LS1
I really never liked this engine
ready for the V8
did the LS6 PCV system
yes, motor mounts on wrong. Figured that out later
adding lightness
to be continued...
ready for the V8
adding lightness
to be continued...
hpt951- Posts : 28
Re: HPT951's track car build
got the engine in:
some under hood wiring
LS1 edit to disable VATS
learned to weld
my first exhaust system!
dynomax ultra-flo. Surprisingly quiet!
cleaned up interior
finishing touches
ready for the track!
What a fun car! The hydroboost is excellent. It really came together quick once I had everything figured out
learned to weld
cleaned up interior
finishing touches
hpt951- Posts : 28
Thats a nice looking setup you have. Goodluck on the track.
I feel a "win" in the future.
Nice exhaust welding and rims by the way.
RobotMachines- Posts : 165
Very nice, what race class will it be in?
Looks fast! What's the unit you have in the metal shielding on the passenger side of the engine bay? Is that an oil pressure accumulator?
Very nice job, I need to learn to weld like that! Good luck with it!
Rich L. wrote:Looks fast! What's the unit you have in the metal shielding on the passenger side of the engine bay? Is that an oil pressure accumulator?
That is a gravel guard I made up for the remote oil filter, while still leaving easy access to remove the oil filter. With the hydorboost and all the related lines, I couldn't find a good way to run the oil lines on the driver's side.
The bat wing wasn't on for that pic, but I use it. I'm going to make a front splitter, and I've always wanted a rear wing - so i think a plexiglass hatch and wing are in order when I get the splitter made up.
I don't run in any class, just going for the DE trophy right now! I may get into NASA since they are starting to make a good presence here in the midwest. I'm a PCA instructor - I just do this for fun
hpt951- Posts : 28
Looks great! Between seeing threads like this and all of my buddies starting to post pictures from track and auto-x events on facebook i am getting super motivated to get started on my car.
Techno Duck- Posts : 447
[You must be registered and logged in to see this image.]" />
Updated pic with my 2014 setup
Have had 2 great seasons with NASA central running TT2. Finally sitting at the right end of my power to weight after a cam install over the winter.
hpt951- Posts : 28
Any idea what she weighs all stripped out like that?
darrenbt- Posts : 9
Right about 2680 with about 1/4 tank of gas
hpt951- Posts : 28
Can we get a sound clip with that exhaust setup?
I'll make a short video when I have time. Last year, I ditched the super quiet dynomax ultraflo for a Daytona prototype tested Aero turbine muffler. I am very happy with the sound of the new muffler. Unfortunately, the only dyno results I have are after the LS6 maifold and ASA cam install; good for about 35 whp and 65wtq gains total
hpt951- Posts : 28
Today at 12:39 pm by Nath1142
