I too can has brake master reinforcement EmptyToday at 7:08 am by gwistrup
I too can has brake master reinforcement EmptyYesterday at 10:12 am by Nath1142
I too can has brake master reinforcement EmptyMon Apr 22, 2024 7:22 pm by lowform
I too can has brake master reinforcement EmptyMon Apr 22, 2024 7:12 pm by lowform
I too can has brake master reinforcement EmptyMon Apr 15, 2024 7:28 pm by JW1970
I too can has brake master reinforcement EmptyMon Apr 15, 2024 6:59 pm by JW1970
I too can has brake master reinforcement EmptyMon Apr 15, 2024 9:51 am by Raymond-P
I too can has brake master reinforcement EmptyFri Apr 12, 2024 3:07 pm by Rob44
I too can has brake master reinforcement EmptyWed Apr 10, 2024 10:09 pm by LS982
I too can has brake master reinforcement EmptyTue Apr 09, 2024 1:54 am by lowform
I too can has brake master reinforcement Empty I too can has brake master reinforcement
Post  robstah Mon Mar 12, 2012 5:41 pm
I too can has brake master reinforcement HDbmF
I too can has brake master reinforcement MTUyg
I originally started with a Sloan brake plate. It was 1/8" stainless steel and even though it had wider coverage than the average plate these days, the flex was ridiculous. I'd say close to 1". This weekend, I picked up a 12"x12" 1/4" thick steel plate and went to work. After building the plate and adding the required angle to the mounting flange, I grabbed a piece of bar stock and welded that on to the upper right corner and tossed a modified A/C adjustment bracket from the original motor on there. I admit it, I stole the reinforcement straight out of the book of xschop. Razz
While I was in there, I drilled out the firewall holes and installed some nutserts. I did the same on the strut tower, but added some jbweld to reinforce it even more. So far it looks a million times better than before, let's hope this fixes my flex. Very Happy
I too can has brake master reinforcement Empty Re: I too can has brake master reinforcement
Post  xschop Mon Mar 12, 2012 6:31 pm
That'll pass the Xschop design module Laughing
I too can has brake master reinforcement Empty Sloan plate
Post  fliermike45 Mon Mar 12, 2012 7:26 pm
Robstah,
Did you bond and bolt the sloan plate? At what point where you getting one inch deflection?
Thanks, Mike
My plate pics:
I too can has brake master reinforcement Cimg1127
I too can has brake master reinforcement Cimg1128
Post  robstah Mon Mar 12, 2012 8:15 pm
Mike,
The flex would happen right at the master. The whole plate would flex outwards in that area.
If you look at the pictures above, you can see the prying marks on the firewall. That's from using some badass 3M double sided tape, made for holding highway signs and other large signs up and attached. Basically, it was a weld replacement tape.
Also, make sure you add an angle to both the brake and clutch masters. Without that angle, you will wear out the pistons very quickly. I had mine spaced off to adjust for the angle in the master brake cylinder and cut away the master clutch cylinder area.
Post  laptop_geek Mon Mar 12, 2012 8:31 pm
I'm not sure why he specified these to be made out of SS, and 1/8" is crazy small too. Lesson here, don't take engineering advice from a graphics designer... I used 3/8" 50 ksi steel (A572) and that sucker isn't going anywhere. I also got it for free as it was scrap Very Happy I can post a drawing of it if anyone is interested. The drawing isn't 100% correct, but the errors are easy to fix.
laptop_geek
laptop_geek
Post  robstah Mon Mar 12, 2012 10:27 pm
laptop_geek wrote:I'm not sure why he specified these to be made out of SS, and 1/8" is crazy small too. Lesson here, don't take engineering advice from a graphics designer... I used 3/8" 50 ksi steel (A572) and that sucker isn't going anywhere. I also got it for free as it was scrap Very Happy I can post a drawing of it if anyone is interested. The drawing isn't 100% correct, but the errors are easy to fix.
If I remember right, he wanted to use aluminum first... Razz
Post  xschop Mon Mar 12, 2012 10:33 pm
1/8" SS.......I too can has a broken flex plate Razz
Post  laptop_geek Mon Mar 12, 2012 10:46 pm
Haha, that would have been great.
laptop_geek
laptop_geek
Post  robstah Tue Mar 13, 2012 1:38 am
Rob, you will like this one. This was at PRI this past year, the Copo Camaro.
I too can has brake master reinforcement ZkuVq
Look at how they "reinforced" their brake master. Cool
I too can has brake master reinforcement I1yv4
