BMW "remote" brake booster
Why does it seem that no one has used the forward-mounted BMW-style brake booster? V8 BMWs have the booster up by the DS headlight with a long rod from the pedal. There seems to be plenty of room up towards the headlight area, so why not?
v2rocket- Posts : 121
Re: BMW "remote" brake booster
I thought about that, studied a bunch of pictures and even mocked-up a bracket. But I wasn't able to get the factory vacuum booster to fit up there anywhere. Maybe a different booster with a smaller outside diamter would work. I also read about vauge pedal feel due to the rod and pivot required. I agree it's an interesting idea.
If it weren't for my truck alternator sitting there, the C5 booster and MC would fit perfectly.
There are boosters of all sizes that could be made to work...not like you need to bolt it to the firewall anymore :p
Hell, an early 924 brake booster is about the size of a pancake, there should be plenty of room along the driver side frame rail if you delete the pop-up headlights. There's even two tapped holes in the rail you could bolt a booster bracket to :p
Knock it out and post pics. The C5 booster already has the C5 MC attached to it.....
I may go to the boneyard today and get some measurements.
Went to the boneyard but didn't take any measurements - shouldn't need to, it really is just a long rod between the pedal action and the brake booster. Don't even need to use the BMW part - you could fab something up easily enough. There should be plenty of room up front in the headlight bucket area for those that have deleted the pop-up lights.
