My conversion , help please :)
Hey guys , I tryed looking for thread like this... didn'd find.
I have a motor from '02 corvette. Alternotor is very high, above steering pump. What can I do? Can I use bracket from Camaro or, what is the best thing to do?
Gudm. Geir ...
Gudm. Geir ...
GudmundurGeir- Posts : 45
Re: My conversion , help please :)
Depends on what accessories you plan to use. You can use the camaro bracket but will also have to use the camaro harmonic balancer.
It's ok to put bolts instead of the ,,drainbolts" (what ever this is called in english) just to close them up, right?
Im not sure what you're saying but.... No, probably not.
I think he means the bleed ports on the master cylinder
Bleed ports ! Thanks (sorry guys ... Icelander , not 100% english)
Those bleed ports can be moved to the other side (where you see the screws). Just reverse the two.
I'd also recommend trying and find a way of creating an angle with the master cylinder. Wilwood says that the angle for the rod needs to be within a 5 degree spec, and what we have calculated here, is a need for 8 degrees. So, you are out about 3 degrees which will cause wear and longevity issues with the master.
There was a thread recently discussing the wedge plates that will work to get you in a better situation.
robstah- Posts : 352
No the bleeder bolts don't fit on the other side
Trouble for me getting parts because I can't get anything hera inch sized ... all mm. A bit of a problem, just a litle bit more time making parts for hydraulics , mm to inch.
But another photo:
But another photo:
Thats a Wilwood MC...the bleeders should fit the other side. Thats why those holes are there. You have to take out the plug screws first.
944-LT1 wrote:Thats a Wilwood MC...the bleeders should fit the other side. Thats why those holes are there. You have to take out the plug screws first.
That, and there might be some check balls in there as well.
uuu... fixed haha .
But one othe question to you guys that use modified Hooker headers...
Can it bu used with the wilwood brake cilinder , it seems so litle space for the headers... ?
Do you know?
Do you know?
I got mine to fit, but it was very tight
tim_nd- Posts : 4
