Possible new engine swap?
+2
RobotMachines
6 posters
Anyone think of this motor as a swap. It looks real appealing.
Dawgz83948- Posts : 603
Re: Possible new engine swap?
What's the appeal over a naturally aspirated V8? Just curious.
RobotMachines- Posts : 165
340 lbft of torque while getting 32 mpg. Pretty sweet!
It'll have close to the same power, better mileage, cheaper than the 944 engine to repair, correct number of cylinders.... LOL!!!! Not that this matters..
I know a guy who works at a GM dealer, he has said alot of good things about this engine, they seem to have out a good amount of effort into building this engine too. I'd like to see how much they are after a couple years time though.
laptop_geek- Posts : 230
direct injection technology makes a dramatic difference in the performace of the later versions.should be able to find in boneyards pretty easy.
stu wright- Posts : 312
Area under curve will be less with the 4 banger. However, maybe a weight savings. And maybe timeslip would be similar.
gamman- Posts : 112
Did anyone see what the rev limit is on these? That would be another advantage if these things could rev higher than a stock sbc (and they should be able to).
laptop_geek wrote:Did anyone see what the rev limit is on these? That would be another advantage if these things could rev higher than a stock sbc (and they should be able to).
Looks like 6500-7000. Kinda hard to see the tach.
