944Hybrids
Welcome to our forum.
» Pacific Raceways near Seattle
Today at 7:26 am by Lemming
» HELP . . . Electrical gremlin
Today at 12:01 am by Rich L.
» Rich's LS powered 944 track car
Yesterday at 8:59 pm by Lemming
» First Time Swap 85 Porsche 944 to LS6
Yesterday at 7:03 pm by kjducati
» Oil and steering cooler options
Yesterday at 6:11 pm by docwyte
» selling conversion parts due to new baby
Yesterday at 4:29 pm by zeusrotty
» Strut brace?
Mon May 14, 2012 5:38 pm by fliermike45
Mon May 14, 2012 1:56 pm by epsylon9mm
» building a 1983 948 on a budget - pointers?
Mon May 14, 2012 7:19 am by Admin
» To " badge or not to badge "
Sun May 13, 2012 5:01 pm by 944-LT1
May 2012
78910111213
14151617181920
21222324252627
28293031
Wilwood rear 300mm kit 5 3 2
Post  xschop on Mon Jan 09, 2012 1:52 pm
Started a mock-up of billet Dynapro radial mount calipers to match the front Wilwood kit I designed. It will fit the factory 951 rear rotors and have bigger pads, but correct piston size availabilty and pad selection than the Turbo calipers Very Happy
Re: Wilwood rear 300mm kit
Post  Lemming on Mon Jan 09, 2012 2:33 pm
Why is it I cannot see the entire photo??? I pressed something in the upper right hand portion of the photo and the next thing I'm being told that I made a negative vote???? Suspect
Post  spence on Mon Jan 09, 2012 5:15 pm
right click the photo and hit "view image"
Clears every wheel....
Post  xschop on Sat Jan 28, 2012 12:31 am
Thanks again to Raymon. Mocked these Dynapro radials up to his 86T 300mm rear discs. Only person I know that has every 944 wheel on hand. I guess you need to when you have 5 P-cars at your disposal. Anyways the 15" phonies (1st pic) clear better than the 16" Fuchs (3rd pic) which has 2mm clearance on the inner wheel well.....16" Early wheel (2nd pic) tons clearance........ all pics are with NO spacers. The Wilwood Dynapro is more compact than the 951 caliper and has the correct piston size availability to match the Factory M.C. and more surface area on the pads to boot Very Happy
Post  xschop on Mon Jan 30, 2012 11:59 am
I had a 928 member confirm these dimensions on a 928S so the same adapter will work on the rear of a 928 as well....
