Tubular Cross Member option?
Hey everyone, been reading this site for a year or so now on and off and finally pulled the trigger on a 951 that I plan to put an LS1 in.
I was considering the standard TPC install kit, but I am now intrigued by the custom cross member TPC made, but can't find any further information on it after this thread:
Was it ever tested with an LSx motor, and how about fitting in a 951? This cross member seems like a much better way of installing a V8 and seems to work around a lot of the problems had with other swaps.
Any information here? I tried emailing TPC but have not received a reply and I can't PM Admin as I have too low of a post count.
-Brian
-Brian
brinskan- Posts : 15
Re: Tubular Cross Member option?
brinskan wrote:Hey everyone, been reading this site for a year or so now on and off and finally pulled the trigger on a 951 that I plan to put an LS1 in.
-Brian
As far as fit is concerned all 944/968 share the same crossmember bolt patterns on the frame so it will bolt into ANY 944/968.
Only 2 more posts (you need 5 to pm)
Dawgz83948- Posts : 603
Thanks.
I could not find this xmember on the TPC website. Am I missing it? Was it ever put into production or is it a custom bit?
-BS
-BS
I made the cross member as an alternative to the oil pan conversion. Now that I have a very good oil pan builder I no longer make or sell the cross members.
Okay, that makes sense. So do you feel the current kit is the best way to go about the swap now, or is it just more cost effective? I know there were some other possible advantages brought up in that thread including no need to run xmember spacers, a possibility to run a different steering rack aswell as getting the motor to sit lower in the car.
Thanks for the answers. Starting to gather all my parts now and would rather be certain on what is the best route.
I think all the worry over the cross spacers are overdone. I am using Admins uprights and setback plates and can get by with .25in spacers. I did have to cut the hood brace/rib.
Yesterday at 11:41 pm by MotoRider42HC
Yesterday at 11:12 am by Nath1142
Mon Apr 22, 2024 8:22 pm by lowform
Mon Apr 22, 2024 8:12 pm by lowform
Tue Apr 09, 2024 2:54 am by lowform
