S2 LSD any good ?
S2 LSD any good ?
My 1990 944 S2 Cab has the 5 speed LSD option.
Will this work well with a ( hopefully ) LS6 swap ?
I see in threads they say " 951 turbo trans " ... are these one and the same ?
I know the 951 and the S2 share many parts , brakes for instance.
Also it has 95000 miles on it ( well maintained and seems to work well ) , is this a factor with a lot more torque in the V8 . Should I consider solid trans mounts , what is to be gained with these. Hope these are legitimate questions. Looking for insight so I can learn.
Thanks and keep it safe.
fittrjoe- Posts : 7
Re: S2 LSD any good ?
The tranny will work fine as long as you don't do any clutch dumps (i.e. drag racing). With that mileage you will be able to tell how well it was maintained once the swap is complete. Do you have the tranny number?
Do not use solid transmission mounts on a 944. There has to be a vibration damper between the tranny and the cross member to which it is mounted. Xschop sells an awesome tranny mount.
Marc
fittrjoe wrote:My 1990 944 S2 Cab has the 5 speed LSD option.
Marc
marc a- Posts : 170
Thanks Mark and no I could not find the tranny # ... And i mean i had a mirror and flashlight wiped area and everthing.( car was up on jacks when I put on the Schnell short shift linkage ) kind of ticked me off because I know i was looking in the right spot per Clarks garage. All indications are it is the original Option code 220 factory Lsd as I did the " wheel spin " check described on rennlist and it checked out positive for Lsd. Just wondering if I gonna want a taller 5th gear put in while doing the Swap? Hate to get it all done then be unhappy with high revs at highway speeds. Should I consider having this looked into while car is apart ?
fittrjoe- Posts : 7
The S2 has very short gearing and with the V8 you'll really want the taller gearing of the 951 box. I had an S2 tranny in my car for a short time and it was a hoot as far as tire shredding goes, but otherwise it was a PITA.
» Drive shaft too short to reach pilot bearning
» 1986 Porsche 944 NA LS1 swap start
» Newb 944S LS1 Conversion
