Banjo Fittings for Wilwood MC
Anyone know where to find banjo fittings for the Wilwood tandem MC? Thanks!
robstah- Posts : 352
Re: Banjo Fittings for Wilwood MC
Any 10mm banjos will work. The bolts are 3/8-24 (for the willwood tandem). I had to cut the bolts down a bit; they where a bit long. I got the bolts from the local parts source.
Alright, I can source the 3/8 bolt, but what about the fittings? It would be real nice to find a banjo that went to female 10mm-1.0mm. All I see are banjos that go to AN, and AN is not an option.
If AN is not an option you may be SOL.... I had to use adapters to mate the stock lines to AN
I think I found some for you.... http://www.brakequip.com/fitting8.html
spence wrote:I think I found some for you.... http://www.brakequip.com/fitting8.html
That's them. Thanks!
Is it acceptable to cut the banjo bolts down? The seal is provided by the washers, right?
That's what I had to do... Everything is OK so far; no leaks... The seal is provided by the crush washers.
Sweet, you just saved me extra shipping and another week of waiting on parts.
