Cleaning Injectors
Cleaning Injectors
I'm approaching the end of my build, any suggestions on cleaning and prepping LS1 injectors prior to the big day?
Re: Cleaning Injectors
Remove, soak in Sea Foam cleaner for a few hours or over night. Remove from cleaner and rinse with can spray carb cleaner, If you want to make sure they are not stuck just drag 12 volts across the two pins of the injectors, they will click. Once they click they should not be stuck or any thing. If you have a helper you can use a rubber tipped blower and blow air threw them at the same time that you drag 12 volts across them. They should spray clean.
I've always sent mine off to witch hunter ([You must be registered and logged in to see this link.] to have the cleaned and checked.
Send them out. Though you can clean them yourself, Eric's instructions are spot on, I doubt that you can verify the flow and spray pattern which is very important. Try and find a vendor that uses ANSU equipment.
