» New 944 widebody & aero
Yesterday at 6:20 pm by scryfst
» ecotec swap
Yesterday at 6:16 pm by sharkey
» Wilwood MC on it's side
Yesterday at 6:09 pm by scryfst
» V8 Conversion Parts
» Fuel pump options
» Poly engine mounts melted
» JP's LS1 Conversion
March 2018
Cleaning Injectors
Cleaning Injectors
Post  fliermike45 on Fri Aug 05, 2011 4:27 pm
I'm approaching the end of my build, any suggestions on cleaning and prepping LS1 injectors prior to the big day?
Re: Cleaning Injectors
Post  Admin on Fri Aug 05, 2011 6:09 pm
Remove, soak in Sea Foam cleaner for a few hours or over night. Remove from cleaner and rinse with can spray carb cleaner, If you want to make sure they are not stuck just drag 12 volts across the two pins of the injectors, they will click. Once they click they should not be stuck or any thing. If you have a helper you can use a rubber tipped blower and blow air threw them at the same time that you drag 12 volts across them. They should spray clean.
Post  Lemming on Fri Aug 05, 2011 6:38 pm
I've always sent mine off to witch hunter ([You must be registered and logged in to see this link.] to have the cleaned and checked.
Post  948 on Sat Aug 06, 2011 7:39 pm
Send them out. Though you can clean them yourself, Eric's instructions are spot on, I doubt that you can verify the flow and spray pattern which is very important. Try and find a vendor that uses ANSU equipment.
