LS1 or LS6 Accessories layout?
For an LS conversion is a 2004 GTO LS1 engine considered a F Body? Also can you use a LS6 out of a 02-03 ZO6 with the stock accessories layout from a vette?
remington7- Posts : 19
Re: LS1 or LS6 Accessories layout?
remington7 wrote:For an LS conversion is a 2004 GTO LS1 engine considered a F Body? Also can you use a LS6 out of a 02-03 ZO6 with the stock accessories layout from a vette?
The F Body significance is related to the front accessory layout including water pump, to make things easy use F Body accessories.
With regards to installing a ZO6 motor (LS6), get the motor then swap the front accessories. I'm running a LS6 Block + Intake with ported 806 heads and custom cam, I thought about trying to use Corvette accessories but decided my time was better spend on other parts of the conversion that require fabrication.
pormgb- Posts : 186
F-body accessories generally work better. I have a 2004 GTO and was not able to use the A/C compressor but could use the alternator.
If I were to buy a LS6 engine how would I swap it to make it have f body acc.'s? Arthro do you have A\C?
The F-body accessories bolt right up to my LS1 2004 GTO block. The block has the same mounting holes, the items themselves have different mounts. I am running an A/C compressor from a F-body. The A/C was the only accessory I had to change.
I have the same 04 GTO engine, I did the A/C compressor wap as well. The GTO P/S pump is a big ugly truck type pump. If you switch to a Turn 1 pump, or an F-Body pump, you will need the F-Body P/S bracket. I think I paid 20 bucks or so for a new one from a local dealer.
for brackets and accessories, you can hit up forums like ls1tech and check the classifieds.
I also used this place [You must be registered and logged in to see this link.] they have kits with everything you need and when they ship out bolt kits(like ps bracket bolts) they come neatly labeled in individual bags.
Schuepbach- Posts : 85
