» Transaxle rebuild
» Tpc LS adapter plate
LS1 or LS6 Accessories layout?
Post  remington7 on Sat Jul 09, 2011 6:36 pm
For an LS conversion is a 2004 GTO LS1 engine considered a F Body? Also can you use a LS6 out of a 02-03 ZO6 with the stock accessories layout from a vette?
remington7
Re: LS1 or LS6 Accessories layout?
Post  pormgb on Sat Jul 09, 2011 7:23 pm
remington7 wrote:For an LS conversion is a 2004 GTO LS1 engine considered a F Body? Also can you use a LS6 out of a 02-03 ZO6 with the stock accessories layout from a vette?
The F Body significance is related to the front accessory layout including water pump, to make things easy use F Body accessories.
With regards to installing a ZO6 motor (LS6), get the motor then swap the front accessories. I'm running a LS6 Block + Intake with ported 806 heads and custom cam, I thought about trying to use Corvette accessories but decided my time was better spend on other parts of the conversion that require fabrication.
pormgb
Post  Arthropraxis on Sat Jul 09, 2011 7:34 pm
F-body accessories generally work better. I have a 2004 GTO and was not able to use the A/C compressor but could use the alternator.
Post  remington7 on Sat Jul 09, 2011 9:56 pm
If I were to buy a LS6 engine how would I swap it to make it have f body acc.'s? Arthro do you have A\C?
remington7
Post  Arthropraxis on Sat Jul 09, 2011 10:01 pm
The F-body accessories bolt right up to my LS1 2004 GTO block. The block has the same mounting holes, the items themselves have different mounts. I am running an A/C compressor from a F-body. The A/C was the only accessory I had to change.
Post  87-944S on Sun Jul 10, 2011 6:54 am
I have the same 04 GTO engine, I did the A/C compressor wap as well. The GTO P/S pump is a big ugly truck type pump. If you switch to a Turn 1 pump, or an F-Body pump, you will need the F-Body P/S bracket. I think I paid 20 bucks or so for a new one from a local dealer.
Post  Schuepbach on Sun Jul 10, 2011 11:49 am
for brackets and accessories, you can hit up forums like ls1tech and check the classifieds.
I also used this place [You must be registered and logged in to see this link.] they have kits with everything you need and when they ship out bolt kits(like ps bracket bolts) they come neatly labeled in individual bags.
Schuepbach
