Oil Filler
Oil Filler
Has anyone found a replacement for the stock oil filler? All I can find are breathers, I want to get rid of the stock unit that sticks up to clear the plastic covers that I am not using. I'd like a cap that fits right onto the valce cover, with no neck. Thanks,
Re: Oil Filler
No way! That is great, I'll do that when I get back this weekend, thanks Eric! A perfectly simple solution, compared to the hoops we jump through to make these conversions work!
Re: Oil Filler
Here's what is going in in place of the stock cap and filer neck:
Re: Oil Filler
beware on mine the cap does screw onto the valve cover without the extension, but does not clear the coil packs if mounted on the valve cover
eclou- Posts : 102
Re: Oil Filler
Tried it out today, I am using the truck coils and it clears by a mile.
