crossover pipe and coolant hoses
is there any pressure going through the cross over pipe on the heads. i bought high temp silicon tubing. I am not sure if there is alot off pressure goping through that pipe, and how do you guys tie in to the heater core. I have some barb to barb 3/4 fittings i was going to use, and what hoses did you guys use to plumb everything in. I am ready to put the motor in but i was wondering on whats the best way to go about the cooling hoses etc.
shwinny- Posts : 80
Re: crossover pipe and coolant hoses
shwinny wrote:is there any pressure going through the cross over pipe on the heads. i bought high temp silicon tubing. I am not sure if there is alot off pressure goping through that pipe, and how do you guys tie in to the heater core. I have some barb to barb 3/4 fittings i was going to use, and what hoses did you guys use to plumb everything in. I am ready to put the motor in but i was wondering on whats the best way to go about the cooling hoses etc.
Up to 18psi since that is your coolant pressure.
Dawgz83948- Posts : 603
That answers one question. Which hose is the feed and which hose is the return on the fire wall. One hose had a valve. Is the hose with the valve the feed. I have to get A different hose for my cross over pipe. I got 10psi high temp rubber silicone hose.
shwinny- Posts : 80
shwinny wrote:That answers one question. Which hose is the feed and which hose is the return on the fire wall. One hose had a valve. Is the hose with the valve the feed. I have to get A different hose for my cross over pipe. I got 10psi high temp rubber silicone hose.
IIRC the valve side is the in and the non valved side is the out.
