Today at 12:03 pm by superman22x
» ecotec swap
Yesterday at 8:41 pm by sharkey
» 86` 944 turbo project
Yesterday at 6:33 pm by 948
Yesterday at 6:27 pm by 948
» LS3 Exhaust
Yesterday at 4:29 pm by Hotrodz of Dallas
» alignment specs
Yesterday at 4:22 pm by Hotrodz of Dallas
» 1984 Gen IV 5.3 Swap
Yesterday at 2:03 pm by superman22x
» Question about 964 transmission into 924s/944
Thu Jan 18, 2018 1:52 pm by Hamr20
Thu Jan 18, 2018 12:36 pm by sharkey
» For sale $150 Griffin for LS1 LS Radiator swap
Thu Jan 18, 2018 12:33 am by jshprd
January 2018
crossover pipe and coolant hoses
Post  shwinny on Wed May 04, 2011 10:46 am
is there any pressure going through the cross over pipe on the heads. i bought high temp silicon tubing. I am not sure if there is alot off pressure goping through that pipe, and how do you guys tie in to the heater core. I have some barb to barb 3/4 fittings i was going to use, and what hoses did you guys use to plumb everything in. I am ready to put the motor in but i was wondering on whats the best way to go about the cooling hoses etc.
shwinny
Re: crossover pipe and coolant hoses
Post  Dawgz83948 on Wed May 04, 2011 10:55 am
shwinny wrote:is there any pressure going through the cross over pipe on the heads. i bought high temp silicon tubing. I am not sure if there is alot off pressure goping through that pipe, and how do you guys tie in to the heater core. I have some barb to barb 3/4 fittings i was going to use, and what hoses did you guys use to plumb everything in. I am ready to put the motor in but i was wondering on whats the best way to go about the cooling hoses etc.
Up to 18psi since that is your coolant pressure.
Post  shwinny on Wed May 04, 2011 3:33 pm
That answers one question. Which hose is the feed and which hose is the return on the fire wall. One hose had a valve. Is the hose with the valve the feed. I have to get A different hose for my cross over pipe. I got 10psi high temp rubber silicone hose.
shwinny
Post  Dawgz83948 on Wed May 04, 2011 4:45 pm
shwinny wrote:That answers one question. Which hose is the feed and which hose is the return on the fire wall. One hose had a valve. Is the hose with the valve the feed. I have to get A different hose for my cross over pipe. I got 10psi high temp rubber silicone hose.
IIRC the valve side is the in and the non valved side is the out.
Post  Admin on Wed May 04, 2011 6:28 pm
Look at this
