How close to the motor can I mount the fluid reservoirs?
I bought a Tilton reservoir that has 3 individual chambers one for each brake circuit and clutch. The unit is made of a thick fiberglass/plastic material. The only space to mount it is behind the motor against the firewall. What do you think?
Re: How close to the motor can I mount the fluid reservoirs?
I'd be more worried about the brake master being so close to the headers.
My plan was to run the reservoirs on the brake master (no remote mounting) and have the clutch master mounted somewhere in that corner (required due to master being sideways). From there, I was thinking of adding a metal plate that attaches to the driver's side valve cover and goes under the master to hopefully reduce the amount of heat that the brake master and that area in general sees.
robstah- Posts : 352
Here is a close picture to what I want to do.
https://2img.net/h/i270.photobucket.com/albums/jj118/nosubt2/tilton%20dual%20system/PICT0054.jpg
Using this unit
http://www.tiltonracing.com/incs/proimage.php?sid=501&m=b
Using this unit
