Coolant Sender Alternative
So far, I have yet to find a solution for the coolant temp sender. The 323-095 is the right spec'ed sender, but finding an adapter for the head to a 1/8-27 NPT is almost impossible. I'd rather not mill down the sender to get it to fit the only adapter on the market.
After a little bit of searching, I thought back to how a local company gets away with an added sender on turbo BMWs. That company provides adapters for the upper radiator hose that has a tap and ground on it for a sender. Here's an example on the bay:
What do you think guys?
I've also thought about drilling and tapping an extra hole for the goofy steam pipes that sit on the front and back of the block.
The spec'd radiator hose in the manual (E71751) has an ID of 33.3mm (1.31"), so would it be wise to go with a 34mm adapter or a 32mm?
robstah- Posts : 352
Re: Coolant Sender Alternative
jagsthatrun.com has a similar connector. If you contact them they will make one to any dimension you need. I got the autometer sender adapter, it didn't fit the sender either, it necks in and it is too long for the sender.
I made an adapter out of of aluminum tube similar to the Ebay item, I machined the ends to make a lip to hold the hose. I then tapped the adapter with M14 x 1.5 and 3/8 NPT holes, this allowed me to use the stock 944 coolant temperature sender + an aftermarket water temperature gauge.
pormgb- Posts : 186
Today at 12:39 pm by Nath1142
