944 Turbo s Transaxle
Is it worth trying to find a TurboS Transaxle for an LS1 car or will the Turbo transaxle with LSD work fine?
tiger2- Posts : 6
Re: 944 Turbo s Transaxle
You'll pay a premium for the Turbo S trans. I'm not sure it's worth the additional cash. If you can find a "regular" turbo trans that has an LSD and a cooler I'm sure it'll be fine.
Turbo s Transaxle
Thanks, read somewhere the Turbo S trans. had a reinforced case and hardened 1St & 2nd gear. Do you know if the regular turbo trans has the hardened gears?
tiger2- Posts : 6
All transmission gears are hardened to some degree. IIRC the S trans has a different material for the main shaft, and therefore different heat treat and mechanical properties.
Until someone comes up with some data proving some improvement, I will not pay a premium for an S trans.
The turbo S transmissions do have a hardened shaft and 1 and 2 gears. Not sure that's worth the price premium though.
docwyte wrote:The turbo S transmissions do have a hardened shaft and 1 and 2 gears. Not sure that's worth the price premium though.
Turbo's have a hardened shaft and 1st gear. The main difference is the hardened 2nd gear. Power shifting a V8 into 2nd, w/o the hardend gear is probably not a good thing.
Dawgz83948- Posts : 603
