Today at 6:52 pm by chrenan
Today at 5:45 pm by AMFCSL
» Tpc LS adapter plate
Today at 5:41 pm by jimbag
» Headers, headers, HEADERS!
» Electric brakes
944 Turbo s Transaxle
Post  tiger2 on Wed Apr 13, 2011 9:01 pm
Is it worth trying to find a TurboS Transaxle for an LS1 car or will the Turbo transaxle with LSD work fine?
tiger2
Re: 944 Turbo s Transaxle
Post  docwyte on Thu Apr 14, 2011 8:20 am
You'll pay a premium for the Turbo S trans. I'm not sure it's worth the additional cash. If you can find a "regular" turbo trans that has an LSD and a cooler I'm sure it'll be fine.
Turbo s Transaxle
Post  tiger2 on Thu Apr 14, 2011 9:10 am
Thanks, read somewhere the Turbo S trans. had a reinforced case and hardened 1St & 2nd gear. Do you know if the regular turbo trans has the hardened gears?
tiger2
Post  948 on Thu Apr 14, 2011 11:49 am
All transmission gears are hardened to some degree. IIRC the S trans has a different material for the main shaft, and therefore different heat treat and mechanical properties.
Until someone comes up with some data proving some improvement, I will not pay a premium for an S trans.
Post  docwyte on Fri Apr 15, 2011 4:05 pm
The turbo S transmissions do have a hardened shaft and 1 and 2 gears. Not sure that's worth the price premium though.
Post  Dawgz83948 on Fri Apr 15, 2011 5:38 pm
docwyte wrote:The turbo S transmissions do have a hardened shaft and 1 and 2 gears. Not sure that's worth the price premium though.
Turbo's have a hardened shaft and 1st gear. The main difference is the hardened 2nd gear. Power shifting a V8 into 2nd, w/o the hardend gear is probably not a good thing.
