Modded RX7 Control Arms
+2
6 posters
Was able to get another set of these built....All 944 dims were CMM verified and transfered to the adapter dimensions. All new graphite impregnated 60a polyurethane isolators pre-installed. Also has a brand new set of replaceable 17mm ball joints and the adapter brackets are made out of 4140 steel that is 4x stronger than the Rx7 joint that was removed from the factory. T6061-T6 billet rear control mount adapters with new rear mount bolts. I will ship with new threadlocker nuts so you can select for either late or early offset position of the balljoint. You can also mount the bracket either on top (V8 swap/1" x-member drop) or below the arm for normal 944 geometry.....
I gave these a brushed alum look, but they are ready to paint if you choose. I shot mine with Red VHT caliper paint and it's still shiney after 4000 miles....
EDIT: Someone asked... they weigh only 7.7 lbs each fully assembled.....
$625 shipped in the U.S...... Just PM for details
Sway bar hookup made easy
The only mod you need to do is thread your factory sway bar links all the way to the bottom (m10 x 1.5 die) and trim them down.....
Factory on left, Modded on right......
Then cut off the excess to where only 1" length of threading shows.......
Re: Modded RX7 Control Arms
I've had this setup for years, with no issues at all. It's been nice to be able to actually replace the ball joints on a late car.
Dawgz83948- Posts : 603
Do caster blocks come with it? Picture shows a set but it isnt very detailed. Let me know, I am very interested.
zeusrotty- Posts : 444
The caster is set at ZERO and I left 1/4" interface between the rear billet block and frame and will send 1/4" X-member/body spacers to help with V8 oil pan clearance as well. They will come with a brand new set of rear mounting bolts too (cap head), you just reuse the front X-member A-arm bolt.
Here's a detailed shot of the inner CNC machining of the rear bushing blocks that fit the aftermarket RX7 bushings perfectly. If you have a good spine there are off-the shelf Delrin inserts for the RX7 arms...
still for sale ? if so pm me info for a shipping to canada Quebec h7r 4p7
matty89- Posts : 62
Guys, I sold every set already. I will make some more this winter. I am re-designing the adapter arm so a 17mm and 19mm Balljoint will bolt right up.
OMG
My god chop you are a metal artist those pieces are simply beautiful
Looks like I can't afford them but I’m saving and wishing LOL
Punisher948- Posts : 39
I'll have a few sets ready by Christmas, i promise. I have been busy building a new crib and the beast is going to paint this weekend ..... Pat Walker style
This may be a stupid question but, I'm still learning about all the suspension upgrades and benefits. What are the bug benefits of this setup on an 88 turbo?
the951racer- Posts : 135
» 1986 turbo control arms
» BNIB modded Wilwood 13/16" clutch master and pushrod
» Rich's LS powered 944 track car
Today at 4:26 pm by Raindoc
Yesterday at 3:06 pm by Rob44
