head gasket
head gasket
Man I forgot which side is up on the felpro head gasket. Is it the grey side or the side with the blue markings going across, searched the web but varying answers and felpro site doesn't show a help section.
Re: head gasket
The gaskets should have "UP" imprinted on them (the blue beading side).
EDIT: You know what.... depending on which felpro gaskets you have, you may have blue up on one side and gray up on the other. Just make sure all water passages line up and make sure "front" is at the front of the engine regardless if its flipped or not.
Re: head gasket
thanks I got them on now. The first time I ever installed a set on the ls motor I got messed up because one front point to the front on the drivers side and the passenger side front points to the rear since the engine is basically cut in half and turned around.
Regardless the blue print side is up. Thank you
