Great customer service from TPC, and new pickup tube lock installed
As most of you know Eric finished my LS1 swap project. Prior to doing some track shakedown runs I noticed that my hot oil pressures were not as robust as I felt comfortable with. I discussed this with Eric who suggested we check the infamous pickup tube O-ring. He volunteered to come R&R my oil pan and install his new pickup tube reinforcement collar.
The existing pickup tube has one mounting flange despite the fact that the block has been factory drilled for 2 retainer bolts. He engineered a simple collar to utilize the second bolt and give more positive clamping to the tube. You can see it on this picture as mounted:
At the same time we changed to a Melling high volume and pressure oil pump and now my pressures are beyond adequate. Hat's off to Eric at TPC
eclou- Posts : 102
» Rod bearing failure. This pickup tube look ok?
» Looking for an LS1 oil pickup
» oil pickup interference
