Clutch options
Clutch options
There seem to be a lot of clutch choices out there from many manufacturers. Why does the Spec clutch seem to be the one of choice? Does it have to do with the finger height when installed on the flywheel? What about all the other brands? Which non Spec pressure plates work? Not much talk out there on this subject that I can find. I'm doing an LS6, stock flywheel in a 1989 S2. Thanks.
patiodaddyo- Posts : 1
Re: Clutch options
i think spec is the go to because they build a clutch kit specifically for an ls in a 944. their clutch isnt just a corvette or camaro pressure plate paired with a random 23 spline disc that may or may not be the correct profile of spline, its all designed to work together.
it likely also helps that the owner of spec clutch has his own ls swapped 944.
sharkey- Posts : 715
Thu Sep 12, 2024 11:13 am by T951
» JP's LS1 Conversion
Mon Sep 09, 2024 6:29 pm by jpkinerk
» 928 Wilwood Integra Caliper Adapters
Tue Sep 03, 2024 7:58 am by xschop
» 930 CV adapters
Tue Sep 03, 2024 7:38 am by xschop
Mon Sep 02, 2024 12:23 am by Raymond-P
» LS2 Mounts
Sun Sep 01, 2024 8:08 pm by jpkinerk
» Solid Transmission Mount By XSCHOP - $125
Fri Aug 23, 2024 10:33 pm by unique202
» 40 Years Old
Thu Aug 22, 2024 8:51 pm by JW1970
» Steering wheel vibration
Mon Aug 19, 2024 12:29 am by Raymond-P
» Clutch options
Wed Aug 14, 2024 9:19 pm by sharkey
