Mon Jul 08, 2013 2:56 pm by Admin
LS2 Mounts
LS2 Mounts
First post , here goes .
I have a couple of questions . Firstly which drawings for the engine mount block plates are correct for an LS2 engine in a 944 ? There are some on the wiki page but also came across some drawings xchop has done and I believe one of them has the wrong dimensions . Will either of these work with the LS2 ?
What solid mounts would I need and the best place to purchase .
I realise TPC sells these complete but being in the UK with postage and Tax it gets expensive so better to fabricate and made to fit .
The engine I have has ITB's and an ARE dry sump pan . Will the dry sump pan clear the front cross member with the uprights as shown in the drawing on the wiki page ? As in , I am looking for clearance measurement between bottom of block and cross member . Not concerned about hood clearance as a race car and hood will be cut for ITB to poke out .
Thanks in advance . Simon
sherry66- Posts : 1
Re: LS2 Mounts
Hello there,
Sounds like a great engine you're working with! As for the engine block plates, the real issue you have is going to be clearing the crossmember with a dry sump pan. While dry sump pans are much shorter than s standard pan, the TPC kit (which most of us use) works with spacers to drop the crossmember 1/2", so the hood will shut. The issue is only a miodified champ pan (which TPC sells) fits properly. Others have modified pans to work as well, but you'll need some good fab skills to do that properly.
For an ARE dry sump pan, you'll need at least 1.5" of added drop to the crossmember, but that's just a guess. If you're committed to that dry sump setup, you'll likely need to fab your own engine mounts and add spacers to the Porsche crossmember, but at that amount of drop, you'll likely see some poor geometry work its way into the front suspension.
All said and done, your best bet may be to fabricate a crossmember that will allow clearance for the pan, but retain the OEM pickup points for the control arm. That or ditch the dry sump for the TPC oil pan and engine mounts.
Hope this helps!
Hope this helps!
jpkinerk- Posts : 179
Today at 8:51 am by 944_GASM
» Monster wide body LT-1 for sale
Sun Sep 29, 2024 6:23 am by 944-LT1
» Ealoken 951 project ( 07k next )
Tue Sep 24, 2024 1:24 am by Ealoken
» WTB LSD Trans for 1986 NA
Sat Sep 21, 2024 9:29 am by uniquaker
» 88 951 LS1 TRACK CAR FOR SALE
Thu Sep 12, 2024 10:13 am by T951
» JP's LS1 Conversion
Mon Sep 09, 2024 5:29 pm by jpkinerk
» 928 Wilwood Integra Caliper Adapters
Tue Sep 03, 2024 6:58 am by xschop
» 930 CV adapters
Tue Sep 03, 2024 6:38 am by xschop
Sun Sep 01, 2024 11:23 pm by Raymond-P
» LS2 Mounts
Sun Sep 01, 2024 7:08 pm by jpkinerk
