Missing "Service Cover" On Bellhousing? (Solved)
Check out these pics, it looks like I am missing something from the bellhousing that TPC sent me???
Any ideas???
Part numbers and/or Amazon links to the missing piece???
Update: Solved:
Thanks!
Any ideas???
Update: Solved:
Thanks!
MotoRider42HC- Posts : 116
Re: Missing "Service Cover" On Bellhousing? (Solved)
Any time an LS uses a custom oil pan you will have that issue. A stock LS oil pan mates to the bell housing, so that scenario doesn't exist with OEM parts. If you install one of these it will cover most of the opening, there will still be two small gaps at the upper corners, but nothing to worry about.
chrenan- Posts : 203
Chrenan,
You are a lifesaver!!!!! Thank you so much!!!
P.S. Should i RTV it to seal it up? I'll be off-road racing with it.
Thanks!!!!
- James
Thanks!!!!
- James
No idea on that one James, all my racing happens on road courses.
» Bellhousing cover
» Bellhousing Contacting Pressure Plate! (Solved)
» Transmission reinforcement plates, We got'em
