» 1988 LS1 Project
Bellhousing Contacting Pressure Plate! (Solved) EmptyYesterday at 4:19 pm by VWTortuga336
» LS Overheating Issue
Bellhousing Contacting Pressure Plate! (Solved) EmptyWed Jun 23, 2021 10:22 pm by stu wright
» 944 na auto sbc
Bellhousing Contacting Pressure Plate! (Solved) EmptyMon Jun 21, 2021 11:07 am by stu wright
» 951 Full Race Car LS swap. Plus a million custom items.
Bellhousing Contacting Pressure Plate! (Solved) EmptySun Jun 20, 2021 12:52 pm by 95ONE
» more pics of the car
Bellhousing Contacting Pressure Plate! (Solved) EmptySun Jun 20, 2021 12:47 pm by 95ONE
Bellhousing Contacting Pressure Plate! (Solved) EmptySun Jun 20, 2021 12:35 am by Raymond-P
» bellhousing pressure plate interference
Bellhousing Contacting Pressure Plate! (Solved) EmptySat Jun 19, 2021 1:23 pm by 9turbo51
» Tips For Mating The Engine To Torque Tube?
Bellhousing Contacting Pressure Plate! (Solved) EmptyFri Jun 18, 2021 8:06 pm by Raymond-P
» ECU Wiring
Bellhousing Contacting Pressure Plate! (Solved) EmptyTue Jun 15, 2021 9:47 am by Hotrodz of Dallas
» wtb: 16" early offset wheels
Bellhousing Contacting Pressure Plate! (Solved) EmptySun Jun 13, 2021 1:17 am by sharkey
June 2021
78910111213
14151617181920
21222324252627
282930
Bellhousing Contacting Pressure Plate! (Solved) Empty Bellhousing Contacting Pressure Plate! (Solved)
Post  MotoRider42HC Wed Mar 13, 2019 8:25 pm
SO...
After putting my engine in the car, we found the crank was seized...
So after taking it all back apart, there were witness marks on the bellhousing where it had contacted the pressure plate, causing the rotating assembly to bind.
I am beyond confused. The flywheel, clutch, pressure plate and bell housing came from TPC in a kit. Yet they don't fit together!?! WHAT???
If anyone has had this issue, and knows the solution, please let me know!
Thank you!!!
- James
UPDATE: SOLVED:
It turns out there was an issue with the sand casting for a small batch of bell housings. The only solution is to take about 1/16" off the contact spots with a grinder.
UPDATE2:
Turns out they forgot to send me the spacer plate...
MotoRider42HC
MotoRider42HC
Bellhousing Contacting Pressure Plate! (Solved) Empty Re: Bellhousing Contacting Pressure Plate! (Solved)
Post  matt889 Thu Mar 14, 2019 10:00 am
are you running truck crank ? with a spacer on the Rear crank seal ?
matt889
Post  MotoRider42HC Thu Mar 14, 2019 10:13 am
Matt,
I am using a L33 5.3L from a Chevy Silverado. And i had specifically let TPC know that before i bought the kit.
I am not aware of any spacers. I installed the flywheel directly to the crank itself.
Is there any specific picture i can take, to help diagnose this issue? Although i don't want to remove the flywheel, because those expensive ARP bolts are one-time-use only.
Thanks for your help!!!
Sincerely,
James
MotoRider42HC
MotoRider42HC
Post  sharkey Thu Mar 14, 2019 1:46 pm
matt889 wrote:are you running truck crank ? with a spacer on the Rear crank seal ?
that was my first thought as well, but the l33 wont have the long crank (only the 6.0l with cast iron heads had the long crank) and it also shouldnt have ever had a crank spacer with that engine as the l33 never got mated to a 4l80e, at least not in a factory application. if the back of the crank flange close to flush with the rear main seal its the way it should be, if it sticks out roughly .400" then its got a spacer or has the long crank.
ive never heard of any ARP bolts being one time use. one of the reasons people buy them is because they can be used multiple times without replacement.
Post  MotoRider42HC Thu Mar 14, 2019 1:49 pm
UPDATE: SOLVED:
MotoRider42HC
MotoRider42HC
