Motor mount spacing
Motor mount spacing
Hey guys
I'm having slight alignment issues
Trying to mount motir mounts
I have early style steel cross member
Measurement between mounts on the cross member and distance from each end
I started with 12 inch off center and cant reach under cross member to tighten the mount one one side
The pan also hits the rack mount one side
Re: Motor mount spacing
Is it possible you have them swapped left to right? I did that the first time I tried. How much room do you have at the firewall? It should be almost none.
What distance mount points do others have?
I wonder I the mounts are too far apart
Sent from Topic'it App
