Brake fitting adapters for wilwood with part numbers
Hey All,
Just finished going through my brakes and found some nifty little adapters that made it much easier. With these, you do not need to cut and reflare etc... Will post pics when I have a chance to take some good ones. Here are the parts...(all from advance auto)
3 x BLU-8C 3/16" (M10x1.0) Bubble flare - connects to stock lines, then to lines below
3 x PAA-0380 3/8"-24 to M10x1.0 line. Connects to above fitting, then to master, bias valve, or t fitting for fronts
My rear line is plumbed to a wilwood adjustable valve, then attached with a simple 3/8"-24 line to the master.
Simple, cheap, and all in one place.
WillSoz- Posts : 8
