which to put in first?
At the moment I have both my trans and my engine out of the car. I still have to fill the trans axle up with gear oil and install a few more items on the engine.
My question is which would be best to do first?
Last time I didnt take the trans out and just swapped engines, pretty straight forward but it would have been nice to been able to wiggle the torque tube while stabbing it.
I am concerned if I do the engine first I wont be able to install the trans properly. What is the opinions of the masses.
Re: which to put in first?
I guess if everything you have is bought it should all fight regardless what you do first? I built my mounts so I had my trans and filled mount installed before I built mounts. I imagine you have the coolest transaxle mount you can get. If adjustments have to be made I would take a little bit everywhere.
Wild Bill- Posts : 121
All my mounts have rubber, I am running a stock trans mount too. Didnt have to money to upgrade to poly mounts yet.
I know people are able to drop the trans with the motor still in to do gear swaps and similar things.
