Wanted: EGR valve pipes, smog pump, vapor/evap canister, and more
I decided to make this my official used parts needed cheap thread...
I still need-
EGR pipes
smog pump
"AIR" stuff, I think?
evap canister
mass air flow sensor
LT1 PCM & Wiring harness (don't know if there is a difference, if so, for a manual car)
AC compressor
Send me a PM or post in this thread. Thanks.
Re: Wanted: EGR valve pipes, smog pump, vapor/evap canister, and more
I have the F body bracket that you need.
Anybody know if the EGR pipes are the same on the camaro and corvette?
They are not. I have the Corvette setup in my car.
Dawgz83948- Posts : 603
Do you happen to know which parts are Corvette specific? Valve, solenoid, tube, etc?
EGR tube and air system is different. The 1 way check valves are the same as is the air pump. Using the Corvette EGR necesitates using corvette headers since the egr tube goes from the passenger manifold to the egr passage on the intake using a solid rigid tube. from the it y's to a check valve that the smog pump connects to.
OK, thanks. I think I am going to need to get a shop manual to figure out how all this stuff hooks up- my engine was a bit more stripped than I was planning on.
Where do you live in cali?
I am in Temecula, half way between LA and San Diego.
You are in the bay area, right? Yeah, that is a bit of a trek. I guess I need to find a good wrecker around here to pull some of this stuff- and see how it is all put together.
I found that diagram, that part of the reason I was wondering if there was a difference between the C4 and Fbody EGR configs.
I cant find a vette one, but I'll snap a pic of mine.
Sometimes these exploded views are tough to figure out without the assembled view to reference.
those EGR pipes are downright scarce. May have to hit up a junkyard.
I just bought some vette stuff from a guy in Arkansas (or something like that) 501-983-1129. Yes #1.
Today at 3:06 pm by Rob44
