» Transaxle rebuild
» Hello, Gentlemen.
» alignment specs
Do all the LS1's come with an electric smog air pump?
Post  docwyte on Tue Aug 03, 2010 9:33 am
I was told only the '02's did, but now some other people are saying they all do.
I need to keep the smog air pump for emissions and it's much easier to mount the electric one vs a belt driven one.
If all the LS1's come with an electric pump, then I can widen my search for motors...
Re: Do all the LS1's come with an electric smog air pump?
Post  Admin on Tue Aug 03, 2010 10:29 am
Is it a must have item? As long as the motor has just what came on it from the factory it should pass your emmision test, Visual and sniffer.
Post  Dawgz83948 on Tue Aug 03, 2010 10:30 am
Only in California.
Post  87-944S on Tue Aug 03, 2010 10:31 am
My 04 GTO engine did not come with an electric smog pump
Post  Bluemach1 on Tue Aug 03, 2010 11:25 am
I took my LS1 from a 2000 T/A. It has an electric smog pump and I will be installing it. I am in California and it is required.
Bluemach1
Post  Porch on Tue Aug 03, 2010 12:10 pm
My '01 did not have a belt-driven smog pump, so i assume it was electric.
Post  docwyte on Tue Aug 03, 2010 12:30 pm
Here in Colorado I need to retain everything that the motor comes with from an emissions stand point. That means the fuel evap needs to work and the smog air pump has to as well.
If all the LS1's came with an electric air pump, we should be all set...
