trying to find axle ratio
I have the trans chart of gear ratios with the final drive. I am not sure if it tells me the axle ratio.
I am looking at upgrading my cam to match the valve springs I have and it is looking for axle ratio, does anyone know what it is on a turbo trans with the early 5th gear swap?
Re: trying to find axle ratio
Is the calculator asking for the total ratio, engine to wheels?
Turbo box final drive is 3.375
Turbo box 1st gear ratio is 3.5
NA Box 5th gear ratio is .7297
In 5th gear; for every one revolution of the engine you get .406 revolutions of the wheel. For the sake of comparison; in first gear you get .08465 revolutions of the wheel for every 1 revolution of the engine.
Does this help
Does this help
I see the different ratios and I under stand the wheel revs per one engine rev, but how do I get a number for axle ratio? I dont know the math for it.
this is what is says:
Vehicle Make:
Vehicle Model:
Vehicle Year:
Vehicle Weight:
Axle Ratio:
Transmission Type:
Tire Height:
Torque Converter Stall Speed:
Vehicle Make:
Vehicle Model:
Vehicle Year:
Vehicle Weight:
Axle Ratio:
Transmission Type:
Tire Height:
Final drive ratio, or axle ratio, is 3.375 for the turbo box.
Ok thats what I was figuring because the final drive is the ring and pinion gear which would be the axle. Thanks.
