How to make a shop ashtray!
Well....I havent posted anything custom or useful in awhile so I made something last night for yall.
Oh yeah this is a "How-To" section.
Whats needed:
-a used brake disc/rotor (I used a Jeep rotor).
-a length of tubing or whatever you got laying around (I used a length of square tubing).
-a used flexplate or flywheel (I used an old flexplate).
-an old caliper (I used one of my old 4 banger calipers from the 944!).
All of this stuff I used before throwing it out.
You can use just about anything to substitute.
Lay the flexplate on the ground and put the tubing vertically in the middle of the flexplate and weld it on. The put the rotor on top of the tubing and weld that on. Cap the hole in the middle of the rotor (my rotor had studs pressed into the rotor so I didnt have to plug those). Then paint all of it black. Then paint the rotor silver!
Then grab your caliper and paint it red! I accented mine with a liddle brush with a paint that mimics zinc and aluminum. Once its dry, weld it to the rotor. Its not functionally correct having a 944 caliper on a jeep rotor AND its upside down as it is in the pics but who cares?!!?! Its cool damnit.
Heres what comes out!
And thats it! Bleeding and anti-squeal not required!!
Whats needed:
Re: How to make a shop ashtray!
Haw farking Nice, will be one of my projects comming up lol.
ffmedic- Posts : 103
what kind of pads did you use?
Tetzuoe- Posts : 178
Shop Sh$T
I don't smoke, but I need a toilet in the shop....any suggestions?
Believe it or not, they are in there as well!what kind of pads did you use?
Of course! But no need for a toilet....you need a urinal!
Whats needed:
Urinal. Mcmaster Carr PN# 2642K95 (roughly 130 bucks)
Urinal cakes. Mcmaster Carr PN# 70285T62 (40 bucks for pack of 100)
Then, send the cakes to Greg. He will put pictures of RH on each. Then do the pee-pee dance!
FRH.
Maybe I can call up RH and get a sticker for the backsplatter of my new McMaster Urinal.....
PORH for real
PORH for real
their sticker will probably crack, and itll take too long, dont they send sticker requests out to another shop?
Idiots'll send em with both sides sticky....and then apologize along with "we're in the middle of switching to a new vendor"
gt1scca- Posts : 795
CF toilet!!!
Send it to Eric....he can make them!
