Would these manifolds work?
Would either of these work?
Corvette LS3: [You must be registered and logged in to see this link.]
Camaro LS3: [You must be registered and logged in to see this link.]
mmacias2- Posts : 6
Re: Would these manifolds work?
The engine, yes!
The LS3 headers, No. I already tried them.
so is the general consensus that no oem manifold will work?
i found the c6 z06 manifolds too. very similar the the sanderson lt1 headers. dont mind the price, im sure they can be found cheaper:
mmacias2- Posts : 6
None of the factory style headers will give you the room to get the steering shaft by them without re-routing it.
