Photographs please
Photographs please
Can anyone please post photographs of the crossmember/engine mount looking down the side of an installled LS1 engine. Both sides please. Thank you.
Re: Photographs please
what are you trying to figure out?
I will try and get the pics tomorrow when I can get the car into the garage and out of the wet cold.
Photographs.
Wow!....I just discovered the Gallery....Thanks Vorsche (and others), great pictures.
I wanted to see just how much space there is (or isn't) between the engine/crossmember/mounts.
Vorsche, is you A/C compressor the stock LS1 Vette unit. You pictures indicates that there is clearance
between it and the frame rail?
Thanks all,
Mike
Thanks all,
Mike
The AC is stock F-Body AC bracket and aftermarket Compressor. We had to SQUEEZE that baby in there, but she sits and cools like an ICE house. Couple of things to get right, Clock the Compressor, and we got the clearance by trimming the Cross member after we got the AC in there to allow the hoses to run between the rails, cross member, headers and everything else stuffed into that tight space. With the new tubular cross member Eric is developing the clearance should not be an issue as all that was considered in the design process.
Keep working on the car, it is so worth the effort, everyday I get to driver her, it just gets better. Ask the BMW M5 who thought he was a bad boy, in the end he had to "talk to the exhaust".
Photographs
Thanks Vorsche, great info.
I know how you feel, I have a 68 MGB GT in which I installed a 3.4 litre GM V6, not a vette beater but it has surprised a few boy racers in rice rockets.
Mike
Mike
