No fuel pump "prime" turning key on.
Continuation of my Optispark post.
What controls/tells fuel pump to Prime when key on to start?
Try to keep this short: Initial issue motor dies after 10 min on restart no prime key on (fuel pump will run if DME relay jumpered)cranks but no start. Let sit/cool key on prime and starts. Fuel pump tests good. DME Relay good.
Since, replaced coil and Opti (Petris). Same issues, confirmed 12v key on power at both Coil/ICM plug connectors, but no spark from coil or plugs.
NOW no prime Cranks no start (with jumper FP runs) no start period. Cold or hot.
Rond948- Posts : 68
Re: No fuel pump "prime" turning key on.
This website is excellent for LT1 troubleshooting info if you haven't seen it yet. It has helped me out a lot.
Rob44- Posts : 38
as i said in your last thread, you need to get a scan tool hooked onto it. first off, see if you even can get communication with the ecm, and then look at the data stream and see if you have a crank signal.
im gonna take a wild stab and say your either losing 12v or a ground to the ecm.
Rond948 likes this post
Still waiting on pcm scan. In the meantime I've been using above site for testing/troubleshooting. Currently recheck
" key on" ICM and Coil harness plug tests no voltage? when I had 12v days ago. Visual inspection of wiring from connectors back into harness nothing obvious (removed tape on connections). Found something strange, to me, there is a common green wire connected to ICM/Coil traced within harness cover back thru firewall to pass footwell pcm location. It has a spade connector but not connected to anything, I noticed this was like this since buying car and 6+ months of driving prior to current issues. There is a porsche harness 2 prong molex (red/red blk) spade connector fits. WTF
Rond948- Posts : 68
» Turbo Transaxle wanted
