LS1 Conversion Shops in the Northeast?
I have a 1989 NA with an LS1 sitting in the engine bay. Now I need someone to help out with the harness etc. and get it running. My play time now is very limited and I need someone to assist.
Can someone recommend a shop? I am located in NY in the Hudson Valley. Will travel to drop off car.
Thanks all!
Thanks all!
87roadracer- Posts : 17
Not as hard as you'd think.
Check out this link Bob gave me for a perfect new standalone harness.
I can't find the other link that gives you a full pdf walkthrough. Of what connector is which and where it connects and what to do with the flying lead wires but after you read that (can do more hunting to find that for you in another person's thread than my own I believe) you'd be surprised how simple it is to do with additional forum advice on here.
Gutterboy- Posts : 230
Today at 4:26 pm by Raindoc
Yesterday at 3:06 pm by Rob44
