LS Conversation Shops in the Mid-Atlantic?
Looking to swap an Chevy Performance LS3 into a 89 S2. My days of having time to do engine swaps are long gone and I'm looking for any recommendations to perform this swap. I'm located in the DC area, but will drive a couple hours if needed.
Thanks in advance for any recommendations.
dcoutofstep- Posts : 12
dcoutofstep likes this post
Re: LS Conversation Shops in the Mid-Atlantic?
Not many shops doing these. We have done several, and have 2 here now to do. One was just shipped in from Tennessee. Have another one from California. We are in Dallas, Texas
I used BodyMotion in Ocean, NJ. They are generally a Porsche shop and have quite a large race team as well. They did an excellent job on my swap (as well as brakes, suspension, etc.). Best time to use them is in the fall. The race team consumes the shop in the spring.
Good luck.
Good luck.
pipeman3rd- Posts : 18
pipeman3rd wrote:I used BodyMotion in Ocean, NJ. They are generally a Porsche shop and have quite a large race team as well. They did an excellent job on my swap (as well as brakes, suspension, etc.). Best time to use them is in the fall. The race team consumes the shop in the spring.
Good luck.
Thanks! I PM'd them to get more info. What conversation kit did you use?
I used most of the TPC kit. Kent's support during the build was exceptional. Worked really well except for the fans and fan shroud. I eventually replaced them with the RH radiator and it works really well.
pipeman3rd wrote:I used most of the TPC kit. Kent's support during the build was exceptional. Worked really well except for the fans and fan shroud. I eventually replaced them with the RH radiator and it works really well.
Kent now makes the shroud to use the stock fans. It works way better.
Any other shop recommendations?
dcoutofstep wrote:Any other shop recommendations?
We've done several 928 and 944 swaps, we're mainly an LS shop who dabbles in Porsche's (I've got 2 928s personally) We're backed up right now, to later in the year, but it is a project we regularly tackle.
(Carolina Auto Masters, Burlington NC, you can email me at jeff at carolinaautomasters dot com)
Good luck, they are really fun once converted!!
milkman383- Posts : 1
Today at 4:26 pm by Raindoc
Yesterday at 3:06 pm by Rob44
